ewutang1983 Posted August 31, 2017 Share Posted August 31, 2017 Hey guys i want to get a little more clearance but was curious id anyone has lidted one before and have any tips. Thanks. Link to comment Share on other sites More sharing options...
thook44 Posted August 31, 2017 Share Posted August 31, 2017 how much more clearance? up to 34mm's, from what i read, you could install spacers at the strut mount without affecting alignment. i'm making some spacers for my '94 legacy to correct the sagging rear and run a slightly taller tire Link to comment Share on other sites More sharing options...
ewutang1983 Posted August 31, 2017 Author Share Posted August 31, 2017 Like 3 inches i was thinking. Link to comment Share on other sites More sharing options...
idosubaru Posted August 31, 2017 Share Posted August 31, 2017 http://www.sjrlift.com/index.php/catalog/lift-kits/0-2-lift-kit-2000-detail on older models people would migrate OBW parts over to their legacy's for additional lift as well, since yours is the same suspension layout that's worth looking into for 2005's as well. Link to comment Share on other sites More sharing options...
ewutang1983 Posted August 31, 2017 Author Share Posted August 31, 2017 Yea that would be nice. Ill look into it seens like a cheaper way to go. Link to comment Share on other sites More sharing options...
Numbchux Posted August 31, 2017 Share Posted August 31, 2017 You'll need Outback struts to fit larger tires. If you want to use Outback struts/springs AND blocks, you'll need subframe spacers. Something more like this kit: http://www.sjrlift.com/index.php/catalog/lift-kits/0-4-lift-kit-2000-detail You'll probably want to contact Scott directly, though. As you'll probably want to mix and match block heights to compensate. Also, that kit is for a 2000-2004, and an 05-09 would be slightly different (at the very least, the rear bushing on the front control arm is different). I like Scott at SJR a lot. He's been around here for a long time. But, if he doesn't offer anything for the 05-09, talk to ADF. They don't list anything with front subframe spacers, but I've seen on their Facebook page and such that they've built a couple really big ones. http://andersondesign-fab.com/product/05-09-legacy-2-strut-spacers-w-multi-link-spacers/ Link to comment Share on other sites More sharing options...
