EA81 Front Bumper Bolts
hey everyone.   My EA81 wagon came with the front bumper zip-tied on.   I have a few questions..
1.   What size bolts do I need to attach the front bumper to the frame rails (4 bolts).  Size and pitch?
2.   On the fenders, where the bumper appears to attach to front quarter panel, the bolts (or nuts) appear to be sheared off.  How does the bumper attach to the fender?  Is there a clip that is bolted to the fender ... then bumper slides over/into the clip?
    Never had to remove/install ea81 bumper... Thanks for the help.
2wd or 4wd?  they are different.
and also chrome 3 piece or one piece skin over frame type?
In my experince the 4 bolts for a 4wd front bumper are 14mm head, m10x1.25.
If it's a 3 piece, you can leave the sides attached to fender and slide off the center portion.
On a one piece, you must undo the 1 or 2 10mm head(m6) bolts from the inside of fender.  don't forget the turn signal wire plugs. before pulling.
