luisg Posted June 21, 2004 Share Posted June 21, 2004 Hello: I live in Argentina. I am buying a second hand Legacy Ouback made in Japan. My former Legacy '95 was made in the US and was OBD II compliant. Does anybody know if a 1999 japanese made Outback is OBD II complaint too? Thanks. Link to comment Share on other sites More sharing options...
BoneCake Posted June 21, 2004 Share Posted June 21, 2004 No Japanese models are OBDII compliant. You may be able to run the motor with a US ECU if you can get one. Then it would be OBDII compliant. Link to comment Share on other sites More sharing options...
JOEK39 Posted June 21, 2004 Share Posted June 21, 2004 The one way to check with certainty is to look for an emissions label under the hood - if compliant it will reference "OBDII". It is possible that even though it was made in Japan, it was made OBDII compliant, so it could be sold in the US. Good Luck, - Joe Link to comment Share on other sites More sharing options...
