GoatFei1337 Posted September 15, 2017 Share Posted September 15, 2017 Hi, I am driving a 2004 Legacy with the EJ251. I've been having trouble diagnosing the P303 3rd cyl misfire. I tried changing the wires, plugs, and ignition coil. It went away for four days and then it came back. I've noticed that it would sometimes turn off during cooler days and it would stay off for like two days before coming back on again. On hot days it would take longer to start and it would come back on. I've also noticed that when the fuel tank is near empty it turns off and then comes back on when I fill up. My only conclusion now is possibly the fuel injector. I am planning on replacing it and see what happens. Any advice and information is greatly appreciated. Thank You Goat Link to comment Share on other sites More sharing options...
1 Lucky Texan Posted September 15, 2017 Share Posted September 15, 2017 was there any oil on the plug wire boot? Link to comment Share on other sites More sharing options...
Downbound Posted September 16, 2017 Share Posted September 16, 2017 Had the same code with my 99 forester. Finally found out it was a burnt exhaust valve. Simple test to check is to hold a dollar bill over the exhaust when it is running and if the bill gets sucked in then blown out it is the exhaust valve. 1 Link to comment Share on other sites More sharing options...
GoatFei1337 Posted September 16, 2017 Author Share Posted September 16, 2017 1 Lucky Texan. There was some dirt/residue on the wires, when they were removed to get the head gaskets and valve cover gaskets replaced not long ago almost immediately after I got the car. Downbound how big of a job is it to replace the valve? If it is the same problem? Thanks for the replies. Link to comment Share on other sites More sharing options...
Bushwick Posted September 17, 2017 Share Posted September 17, 2017 If it's a valve, you'd have to pull the head. Since the heads on these are like baby inline 4 heads, it's pretty straightforward to remove a head. However, before doing that, connect a vacuum gauge to the engine and see what's it's doing or if points at a valve. Can try reading this: https://www.motor.com/magazine-summary/mastering-the-basics-reading-a-vacuum-gauge/ or google "engine vacuum testing". Lots of sites have tips on how to read. Gauges cost $15 roughly. You can T into a proper vacuum source, and rest the gauge on the windshield (slip under hood gap with hood up) and watch from in the car. FWIW, I bought a 99' Continental with running issues (it barely ran) @84k miles. Guy I got it from was in over his head with it and bought it at auction. It had one CEL code (forget what atm) and the guy kept saying something was wrong with cylinder 3. After a quick inspection, I found the wires going to the coils (V8 engine, so entire side i.e. 4 cyl. had a lump of wires going to coils) had been chewed on; the rodent was thorough, as every single wire in the bunch had a 3/4" section where the rubber was completely stripped from EACH wire! I cut each wire and soldered back and had heat shrink on each. Car ran better, but still had a misfire (it wasn't throwing a code though). This time, I removed each coil out of circuit and took my ohm meter and probed the center (output going to spark plug) and then carefully probed a connector pin on the coil. I checked both pins separately while leaving other probe on center output. 7 of the coils had virtually identical readings. The last one was 2 ohms too low. Got a new coil and have a great running car I got for nearly nothing. Anyhow, the point of that anecdote was there was code, but the underlying issue was the wires had been tampered with (stupid rodent, found it's nest under the intake upper) and many were touching each other, and even after fixing that, it took checking each coil to verify a secondary fault was there as well. I'd check each coil. If they all check out with identical readings (mind you, my good coils read 4.5 ohms, and the bad one read 2.4 ohms, so that's enough of a difference) , try swapping coils around, reset the code, and see if it appears on a different cylinder i.e. P0302 (cylinder 2), etc. Trace the wiring to that coil back as far as you can (if it's wrapped or under plastic sleeves, probably OK, anywhere the actual wires might be exposed i.e. you see the color of the wire, is where you wanna see if there's copper showing. Also look closely for burns or melted sections. Link to comment Share on other sites More sharing options...
06SubLegTx Posted September 17, 2017 Share Posted September 17, 2017 On 9/15/2017 at 3:29 PM, GoatFei1337 said: Hi, I am driving a 2004 Legacy with the EJ251. I've been having trouble diagnosing the P303 3rd cyl misfire. I tried changing the wires, plugs, and ignition coil. It went away for four days and then it came back. I've noticed that it would sometimes turn off during cooler days and it would stay off for like two days before coming back on again. On hot days it would take longer to start and it would come back on. I've also noticed that when the fuel tank is near empty it turns off and then comes back on when I fill up. My only conclusion now is possibly the fuel injector. I am planning on replacing it and see what happens. Any advice and information is greatly appreciated. Thank You Goat Are these subaru parts or aftermarket ones? Link to comment Share on other sites More sharing options...
GoatFei1337 Posted September 19, 2017 Author Share Posted September 19, 2017 06SubLegTx, they are aftermarket ones... Link to comment Share on other sites More sharing options...
montana tom Posted September 19, 2017 Share Posted September 19, 2017 Might check your valve adjustment, in 04 I believe it is .16 intake and .21 exhaust Link to comment Share on other sites More sharing options...
GoatFei1337 Posted September 29, 2017 Author Share Posted September 29, 2017 (edited) Hey guys thanks for all the replies. Sorry I've been busy. But I've noticed that whenever I turn the air conditioning on the tach will fluctuate every few minutes or so and the CEL will blink once. Then sometimes it will shudder (misfire?) once or twice every few minutes at idle. This happens only when I turn on the a/c. Also if it the day is cold like under 60 degrees then the CEL will shut off and the car will turn on really fast, but if it is above 70 degrees and warm/hot then the CEL comes back on and it will take several seconds for it to start. Thanks Goat Edited September 29, 2017 by GoatFei1337 Link to comment Share on other sites More sharing options...
GoatFei1337 Posted October 20, 2017 Author Share Posted October 20, 2017 Hi guys, I tried doing a compression test on the 3rd cyl. (misfiring cylinder) and it came back out with a normal reading of 125. But the really bad part is the adapter to the compression tester is stuck in the spark plug socket and now I can't get it out. I'm sorry if this is a stupid mistake but I was wondering if anybody has any tips or tools advice to get it out. I was told that bolt/nut extractors would work. Thanks Goat Link to comment Share on other sites More sharing options...
