damnsubaru Posted September 20, 2017 Share Posted September 20, 2017 my book is a 86 and my dl wagon is an 88. will the book work or did they change from 86 to 88? Link to comment Share on other sites More sharing options...
jsyme Posted September 20, 2017 Share Posted September 20, 2017 Well the 86 and 88 Engine difference is carb vs. fuel injection, vacuum hoses, loom or wiring harness and fuel pump pressures. https://en.wikipedia.org/wiki/Subaru_Leone https://en.wikipedia.org/wiki/Subaru_EA_engine You may have an EA71 or an EA82 engine. As as owner's guide it's probably exactly the same. If it's a Haynes or Chilton's manual it's mostly correct. And the most change will be found in the Subaru Service manual for 1986 and 1988. If your book is a copy of Stephenie Meyer's "Twilight", I think we can all agree that the Owner's manual is still a better romantic novel. If your book is the Bible, God's Word never changes, and He loves you very much. Nothing changed between 88 BC and 86 BC If your book is George Orwell's "Nineteen Eighty Four" both engines are carb'ed and it doesn't matter because you're living in perpetual war under omnipresent government surveillance. If your book is actually an 1988 newspaper President Ronald Reagan is the most powerful man in the world and we have a reason as to why the Speedometer runs best at 55 MPH in 5th gear in the NA. What is your book? 1 Link to comment Share on other sites More sharing options...
Gloyale Posted September 20, 2017 Share Posted September 20, 2017 Most everything will be the same chassis wise. Differences include changes to the headlight switch, and wiper switch (stalk mounted in 88, dash mounted in 86) Also, there is a section on SPFI in the 86 book, but the wiring on the early systems is slightly different.....notably the wiring to the distributor. The pins shown at teh ECU for reference and signal pulse from the disty are flipped on the 88 from what is shown. (changed after 87) Headlight adjuster slightly different But that 86 FSM will be better than a haynes or chiltons anyday. 1 Link to comment Share on other sites More sharing options...
damnsubaru Posted September 21, 2017 Author Share Posted September 21, 2017 it is hard to find a factory shop manual. I downloaded the one from bumble bee, but that's as close as i can get. Link to comment Share on other sites More sharing options...
subpoop Posted January 13, 2019 Share Posted January 13, 2019 i found a book called how to keep you subaru alive and i bought the book how to keep your volkswagon alive and used it to fix my friends bus butr when he sold it he gave them the book as well. Link to comment Share on other sites More sharing options...
sparkyboy Posted January 16, 2019 Share Posted January 16, 2019 I love those old 70s and 80s hippie repair manuals Link to comment Share on other sites More sharing options...
