steve56 Posted September 24, 2017 Share Posted September 24, 2017 (edited) Last fall bought 2003 ej253 that came from Copart car..The donor car was hit in front.. Engine damage is broken drivers side timing belt cover.Timing belt is still on with all timing marks in correct position. Just did a leak down test on engine.Getting 80 percent leak down on all four cylinders at exhaust ports. No piston ring leaks and all four spark plugs have an even ware pattern with no oil fouling. I want to get correct diagnosis. without pulling the heads, because I'm selling the engine. Doing complete rotation of engine from crank bolt, I'm getting 80 percent leakage thru exhaust ports on all cylinders.So I will do valve lash adjustment on all intakes and exhaust and redo test.. Edited September 25, 2017 by steve56 Link to comment Share on other sites More sharing options...
Mike104 Posted September 24, 2017 Share Posted September 24, 2017 Exhaust valves leaking? Seems odd to be all four though. Link to comment Share on other sites More sharing options...
987687 Posted September 24, 2017 Share Posted September 24, 2017 Check the valve clearance and adjust them. Exhaust valves tend to get tight over time. 2 Link to comment Share on other sites More sharing options...
GeneralDisorder Posted September 24, 2017 Share Posted September 24, 2017 They bend intake valves, not exhaust, if the timing fails. And if it were going to have a partially burned exhaust valve it certainly wouldn't be on all four cylinders. Therefore I declare your testing method to be faulty. Those are implausible results. GD 1 Link to comment Share on other sites More sharing options...
Fairtax4me Posted September 25, 2017 Share Posted September 25, 2017 (edited) Testing using the wrong marks. Arrows mark TDC. Arrows need to be at 12, 3, 6, and 9 when doing leak down test or the valves on the cyl you're testing will be open. Timing hash marks are 45° off on cams and 90° off on the crank. Using timing marks for a leak down test, the Pistons will be at mid stroke and exhaust valves will be starting to open. Edited September 25, 2017 by Fairtax4me 1 Link to comment Share on other sites More sharing options...
steve56 Posted September 25, 2017 Author Share Posted September 25, 2017 What marks do I use for adjusting valve clearance. Rally Suby! suggested my exhaust might need to be adjusted. Link to comment Share on other sites More sharing options...
Fairtax4me Posted September 26, 2017 Share Posted September 26, 2017 Arrows for valve clearance. -> TDC Link to comment Share on other sites More sharing options...
steve56 Posted September 26, 2017 Author Share Posted September 26, 2017 So are the arrow marks for tdc at 12 and 3 for the right head and at 6 and 9 for the left head? Link to comment Share on other sites More sharing options...
Mike104 Posted September 26, 2017 Share Posted September 26, 2017 (edited) The attached pages from the service manual tell you how to put the valves in closed position (TDC) Pages from 2003 Forester Service Manual.pdfFetching info... Edited September 26, 2017 by Mike104 Link to comment Share on other sites More sharing options...
