mtsmiths Posted September 24, 2017 Share Posted September 24, 2017 Do I have to pull the door panel off, or can the switch cluster be prised out of the armrest without buggering everything up? One cracked window switch button, hopefully can be 'glued' so I don't have to replace entire cluster. Link to comment Share on other sites More sharing options...
gbhrps Posted September 25, 2017 Share Posted September 25, 2017 mtsmiths, These two pdf files are from the 2006 OutBack Factory Service Manual. Read it carefully through a couple of times before you attempt. None of this stuff is hard to do, if you're used to wrenching on cars. Newer DIYer's need to slow it down and take care doing these kinds of things, to keep from breaking off various lock tabs and scarring up the plastic bits. Good Luck! 3 Power Window Control Switch.pdf 17 Door Trim.pdf Link to comment Share on other sites More sharing options...
mtsmiths Posted September 25, 2017 Author Share Posted September 25, 2017 Thanks for the links, been dere, done dat, I feared as much ... just hoping against hope I could pop the thing out. zi'll get to it as soon as I get the BACK door back together for broken door handle. Living close to the ocean in the tropics is a bitch on cars! Link to comment Share on other sites More sharing options...
gbhrps Posted September 26, 2017 Share Posted September 26, 2017 mtsmiths, I've wrenched on all kinds of cars over the years and many of them allow the power window switch assembly to be popped out of the door arm rest. Then there are the ones that you try that with, only to discover that the door panel must come off first, so you can remove the screws that hold the switch in place. Trying to pop thos off (the ones with the screws underneath) ends up breaking switch cases, and adds a whole new problem for you. Having not had an 06 door panel apart before myself to know how subie did it on that year, I'd suggest going the cautious route, and check the back of the switch assembly in the door panel to see which applies . Then again, maybe someone whose done it on that generation subie can jump in and say for sure. Link to comment Share on other sites More sharing options...
Mike104 Posted September 26, 2017 Share Posted September 26, 2017 Looks like it's attached from the back side with screws. My thought would be that you would need to remove the door panel to get access Link to comment Share on other sites More sharing options...
mtsmiths Posted September 26, 2017 Author Share Posted September 26, 2017 (edited) gbhrps, do you have sheet EI418? There's something hang up the front of the door panel, and damned if I can see what it is. So near and yet so far. Never mind, found it Mahalao, all Edited September 26, 2017 by mtsmiths Link to comment Share on other sites More sharing options...
