Intermittent loss of power part 2
after solving the knock sensor issue with the last post I made, http://www.ultimatesubaru.org/forum/topic/164225-intermittent-loss-of-power/?do=findComment&comment=1364460, it is losing power differently this time .
my wife has been driving it and it  would never fault on me until one late night making a run to the store,
i was driving up a fairly steep hill and going up at about 40 it held there for around 5-6 seconds and like a switch it comes alive and
takes off up the hill.
i kinda have an idea where to look but could use some input
it also occasionally dies on start up but you fire it up again and is just fine
Air injection solenoid is that dohickie with the two hoses bolted to the front of the #1 intake runner. Might be unplugged.
Power for that comes from the main relay. Check at the connector for 12v. Ground goes straight to the ECU.
ECU controls opening/closing of the valve during certain RPM ranges and throttle. It should be closed at idle. If it's stuck partly open it creates a vacuum leak.
Check for any other loose or split vacuum hoses and breather/PCV hoses.
What kind of knock sensor did you install? The Cheapo eBay sensors sometimes cause problems.
Edited by Fairtax4me
