Strut mounts - two - defective?
A few months ago I bought two rear struts and mounts from RockAuto. Mounts were low priced. The left rear mount/strut working great. The right rear mount's mounting hole has broken free from the surrounding rubber mount causing the strut to push up about an inch above the top of the mount. I assumed it was defective. I replaced it a month ago - same mount off RockAuto site. It is broke same as last time after a month of use. Hard too believe I had two defective mounts. If low price was the reason why hasn't the left rear given out? I also thought maybe a plate or washer should site on top of the strut rod lip immediately under the mount but the left rear does not have a washer or plate - did I get the struts and both were missing this washer plate? Or do I purchase a more expensive mount and that solves my problem? Looking for thoughts on missing parts? washer/plate or just a case of buying a cheap mount? Or is the strut rod shaft somehow binding and eventually pushing its way through the mount?
....Milty
What kind of struts?
Are your springs old? Sagging? Drive anywhere that makes the rear of the car bottom out over a driveway entrance/ pothole/ rough road/ etc?
If the strut is bottoming out or overextending it can break the mount.
Cheap mounts are usually not great quality, but I would expect them to last longer than a month.
Another thought, often the rear mounts are side specific. What brand and part numbers did you order? They also have to be installed in correct orientation, might have an arrow on the mount that indicates which direction the mount should face when installed.
Edited by Fairtax4me
  • Like 1
Rear struts - hydraulic oil I don't have the "brand" name/part number at the moment - off RockAuto online I believe middle of the pack for cost. Springs are original. I had the first mount replaced at a car shop - no mention of any spring issues or strut issues. Not sagging. Avoid all bad road conditions.
The bottoming out or overextending would be all related to the coil springs remaining capability? Or a defective strut. Prior to mount breaking I have bounced the car up and down multiple times via the bumper and driven bumpy country roads and it it seems to do its job.
...Milty
Don't buy cheap mounts.
I've had them fail completely in less than a week.
Including rear passengers side 95-99 EJ strut mounts.
Others have had similar failures and issues. Another forum has a picture posted of how badly they bulged upwards atbthe cushion he replaced them before they failed but the pics were awfully funny.
Here's my options to avoid wasting time:
Reuse originals
Used Subaru
New KYB or Subaru
I'm not wasting my time. I had a bunch of brand new MOOGs, probably good parts, and I didn't even want to try them. sold my last one yesterday thank goodness I won't be tempted to use them now. LOL
Edited by idosubaru
  • Like 1
I agree - not 100% sure its entirely the mount that is the root cause but it was a cheap one - I will spend money on the replacement mount - and once the strut/coil is out - going to look it over as best I can to determine if the coil or strut are part of the issue.
...Milty
I plan to replace mount this weekend - bought a Moog  - beyond visually inspecting the coil and strut for any defects or binding either compressed or extended - any other methods to detect a bad original coil or newly purchased strut?
...Milty
