87.5- MPFI engine loom plugs/pins
I'm making a patch loom to install a Spider manifold XT engine into my turbo wagon.
I've traced all of the pins on the 2 loom plugs & there's only some minor changes.
Problem is that the spare engine loom I'm using as an extension is from an NA. It uses all 16 pins on the black plug like the turbo, but only 11 of 16 on the white instead of 12.
Therefore, I'm one pin short on the engine side of the loom.
Does anyone have a spare loom they'd pull a wire out of, or know where I could buy these pins?
Thanks in advance.
  • 4 months later...
