Hey Guys looking for a little direction and were to go from here. I have done a lot of work to this car and need to get it through inspection.
 This 1999 legacy had a engine swap before I bought it and now has a 2.2. The previous owner did not have emissions so when I first got it I had to change the intake and get one with a EGR. This has all been done the car runs but has a miss on cylinder 3 & 4 and a EGR flow malfunction.Not sure were to go from here I put a timing light on spark plug wire 3 &4 and both are showing a erratic flash indicating a miss could the coil be getting a bad signal I swapped coils and the problem was still present.
  • 3 weeks later...
Cylinder #1 145
Cylinder #2 145
Cylinder #3 150
Cylinder #4 135
These were done on a cold engine and removed only the plug from the cylinder that was being checked.
The car seems to run without a miss at times. Missing is most present at low RPMs under load.
