Ricohelo Posted October 7, 2017 Share Posted October 7, 2017 No start, I’ve tested for spark, good, fuel pump is working, when I placed the Noid tester on injector, no signal. Quote Link to comment Share on other sites More sharing options...
GeneralDisorder Posted October 7, 2017 Share Posted October 7, 2017 So now you need to find out if you have +12v, ground signal, or neither. Keep going..... GD Quote Link to comment Share on other sites More sharing options...
Ricohelo Posted October 7, 2017 Author Share Posted October 7, 2017 I have 12 volts, no grad signal Quote Link to comment Share on other sites More sharing options...
Ricohelo Posted October 7, 2017 Author Share Posted October 7, 2017 No ground signal Quote Link to comment Share on other sites More sharing options...
GeneralDisorder Posted October 7, 2017 Share Posted October 7, 2017 Then the ECU is not firing the injectors. Check that the cam sensor signal is present. GD Quote Link to comment Share on other sites More sharing options...
