nicksubaru Posted October 10, 2017 Share Posted October 10, 2017 I have a bad wheel bearing on the driver side of my ob. I dont have a press. But i do have a 92 legacy parts car. Would the hubs swap over? Most ej stuff are interchangeable that's why im asking Link to comment Share on other sites More sharing options...
Gloyale Posted October 10, 2017 Share Posted October 10, 2017 it would work for driving but the ABS tone ring/sensor setup is different and not compatible. Link to comment Share on other sites More sharing options...
idosubaru Posted October 10, 2017 Share Posted October 10, 2017 What he said - if you're willing to loose ABS then yes you can sway away. If the tone rings have the same number of teeth you could maybe splice the 92 sensor onto the 00 sensor plug. It only needs to see the pulses from the tone ring and if they're the same number of teeth then it might work? I've always wanted to try it but never had a situation that needed it. Link to comment Share on other sites More sharing options...
idosubaru Posted October 10, 2017 Share Posted October 10, 2017 also you could just get the correct part: www.car-part.com 1 Link to comment Share on other sites More sharing options...
lmdew Posted October 10, 2017 Share Posted October 10, 2017 I have the correct hub, removed from a low mileage CO rust free car. $80 shipped. Link to comment Share on other sites More sharing options...
