macksterminator Posted October 10, 2017 Share Posted October 10, 2017 Hey everyone! I am thoroughly stumped! hopefully someone out there can help! I received this 99 forester with a blow HG, it sat for 2-3 months before being worked on. No major hiccups in disassembly/reassembly. Now that its all back together it starts right up the first time but will only run for a few seconds then shuts off ( while pumping out white smoke). You can keep it running with the pedal but the second you stop giving it gas it dies immediately. What I do know is; No codes thrown on Boshc reader Spark is good Compression good All vac lines connected/airbox fully assembled All vac lines replaced besides the large diameter Y shape hose between PCV/airbox and valve cover breathers Fuel rails, pressure regulator and injectors cleaned by hand New fuel pump Fuel filter not replaced because fuel flows steadily out Fuel pressure solenoid switched with one that works(wrong name? ( green cylinder with prongs under drivers side dash by left knee) Link to comment Share on other sites More sharing options...
1 Lucky Texan Posted October 10, 2017 Share Posted October 10, 2017 triple check the hose from the IACV under the intake tubing. 1 Link to comment Share on other sites More sharing options...
Evil02outback Posted October 11, 2017 Share Posted October 11, 2017 Run a compression check Link to comment Share on other sites More sharing options...
Gloyale Posted October 11, 2017 Share Posted October 11, 2017 Fuel pressure solenoid switched with one that works(wrong name? ( green cylinder with prongs under drivers side dash by left knee) I have no idea what you are talking about here. Are you talking about the fuel pump relay? IDK not the issue I would suggest check the MAF Connector? Link to comment Share on other sites More sharing options...
1 Lucky Texan Posted October 20, 2017 Share Posted October 20, 2017 any progress? Link to comment Share on other sites More sharing options...
1 Lucky Texan Posted December 8, 2017 Share Posted December 8, 2017 bump Link to comment Share on other sites More sharing options...
