Rossta86 Posted June 21, 2004 Share Posted June 21, 2004 I've searched for this, but i havn't found any answers so if they are out there im sorry for asking again. What settings are you guys with webers running for your float level and float drop. I have the dfev instead of the dgev, but im pretty sure the specifications for the float level and float drop will be the same. Thanks Link to comment Share on other sites More sharing options...
GeneralDisorder Posted June 21, 2004 Share Posted June 21, 2004 Probably depends on which DFV you have. There are several with different sized venturi's. Is is a true DFV or a Ford version (holley 5200 series)? GD Link to comment Share on other sites More sharing options...
Rossta86 Posted June 21, 2004 Author Share Posted June 21, 2004 MY mistake i should have mentioned it it is a holley 5200. I have a data sheet telling the float levels and float drops of most of the vehicles using the holley 5200 non feedback carb. If nobody has a definite answer i believe i will just find a vehicle with a motor of the same displacement and use that as a start. Sound like a good idea? Link to comment Share on other sites More sharing options...
GeneralDisorder Posted June 21, 2004 Share Posted June 21, 2004 Maybe leaf through a haynes manual for a 5200 equiped Ford at the local parts place..... or call a Ford dealership and ask them to look it up. LOL. Sounds like your data sheet will have the answer. As long as you know the size engine your carb came from. GD Link to comment Share on other sites More sharing options...
Rossta86 Posted June 21, 2004 Author Share Posted June 21, 2004 i'll go ahead and try that, thanks for the quick responses man. Link to comment Share on other sites More sharing options...
chef_tim Posted June 21, 2004 Share Posted June 21, 2004 Try this post...... http://www.ultimatesubaru.org/forum/showthread.php?t=16892 Tim Link to comment Share on other sites More sharing options...
Rossta86 Posted June 22, 2004 Author Share Posted June 22, 2004 chef_tim said: Try this post...... http://www.ultimatesubaru.org/forum/showthread.php?t=16892 Tim Thanks for the reply. One question though, the float measurements on the diagram are in millimeters correct am i correct? Link to comment Share on other sites More sharing options...
Rossta86 Posted June 22, 2004 Author Share Posted June 22, 2004 nevermind i see it now just didn't look close enough Link to comment Share on other sites More sharing options...
