2001 outback timing belt tensioner bolt snapped
Tensioner bolt snapped while running ??? never heard of that before.  Yes most likely you have bent valves. Amazing it runs.  Do a compression test or pop a valve cover and see if the valves are staying compressed.  The section of the block where the tensioner mounts is replaceable.
Most likely they stripped the bolt or just over tightened it and walked away... Some people should never touch a wrench. Pistons should be fine, new head gaskets, new valves and seals and you should be good to go. Oh yea you'll have to give your mechanic a pail full of $ as well...
The aftermarket kits come with a replacement bolt, that should not be trusted, I’ve seen those shear off before. You can tell by looking at it m, the head and shank won’t be the same form and color as OEM.
Bent valves, usually a majority or bunch of intake valves.
You can also get two used heads and swap them out. That would be cheaper than a valve job.
