'95 legacy fuel pump runs constantly without key in ignition
My neighbor has a '95 legacy wagon, I replaced fuel filter, replaced dead pump, relay checked out, sending unit seemed OK. Now the fuel pump runs constantly without key in ignition, it will run battery down overnight. The car starts and runs.  Manual suggested  MAF, pressure sensor.
Has anyone had a similar issue?
Relay is the only way the pump gets power. Remove the relay and see if it shuts off. If it does either the relay is stuck on or the coil control circuit for the relay is grounded and keeping the relay on.
Edit: read op wrong.
Edited by Fairtax4me
