Subieguy Posted November 13, 2017 Share Posted November 13, 2017 The transmission in my 78 Brat has gone bad. I have no idea what is wrong with it but I have a replacement transmission for it. I really am just looking for some help with finding the correct oil seals for it. Specifically the oil seals where the axles mount to the transmission and back at the shifter. The usual chronic places where our transmissions leak. Also, is there anything I can buy for the shifter bushings? Thanks. Richard Link to comment Share on other sites More sharing options...
moosens Posted November 13, 2017 Share Posted November 13, 2017 Those were all available as of a couple of years ago. Probably can still score. What was the tranny doing or not doing ? Link to comment Share on other sites More sharing options...
Subieguy Posted November 13, 2017 Author Share Posted November 13, 2017 The transmission just started making this strange grinding noise. I thought something was wrong with the left CV axle. It was going bad. I had a new replacement so, I changed it. Didn’t help at all. I put it up on jack stands so the front wheels were off the ground. I put it in first and it would not freely move the wheels without giving it a lot of gas. It vibrates really bad too. It shifts fine. Definitely not the clutch. Paul, you wouldn’t happen to know any of the part numbers for any of the oil seals I need would you? Link to comment Share on other sites More sharing options...
moosens Posted November 13, 2017 Share Posted November 13, 2017 I feel like a knucklehead - typical - but I know I saved those numbers but where they are now is beyond me. I sure will try to locate them. Pretty sure I saved the receipt from the dealer. Lots of guys seem to have the Factory parts manuals , and maybe even some posted online. Mine are not handy at the moment. Link to comment Share on other sites More sharing options...
moosens Posted November 13, 2017 Share Posted November 13, 2017 There’s at least two or three trannies here is you need one. All good , early top starter single range. If you’re in a pinch I could send one. Your description sounds like the differential but tough to tell. Link to comment Share on other sites More sharing options...
Jonv23 Posted November 14, 2017 Share Posted November 14, 2017 The transmission just started making this strange grinding noise. I thought something was wrong with the left CV axle. It was going bad. I had a new replacement so, I changed it. Didn’t help at all. I put it up on jack stands so the front wheels were off the ground. I put it in first and it would not freely move the wheels without giving it a lot of gas. It vibrates really bad too. It shifts fine. Definitely not the clutch. Paul, you wouldn’t happen to know any of the part numbers for any of the oil seals I need would you? I have a factory parts manual in PDF form. If you send me your email in a PM, I can try to email it to you. For what it's worth, you can still find parts if you really scour. I just bought a factory original, NOS 4 blade fan for my 79 BRAT. It came out of the UK, but the parts are out there. Link to comment Share on other sites More sharing options...
Subieguy Posted November 15, 2017 Author Share Posted November 15, 2017 I have a 1979 Parts manual in PDF. It's just not clear on the oil seals for the transmission. In fact, I don't even see a picture of the ones that go where the axles mount to the transmission. Link to comment Share on other sites More sharing options...
impostor Posted January 25, 2018 Share Posted January 25, 2018 I'm late to the party, hopefully you have this resolved by now. I'm not much help on the axle seals, but I can tell you the shifter rail seal is actually an oring. I replaced mine a few years ago. Unfortunately the only way I could disassemble everything to replace it was to remove the transmission from the vehicle. Paul, would you happen to know the part number for the bushing and the rubber boot? Link to comment Share on other sites More sharing options...
moosens Posted January 26, 2018 Share Posted January 26, 2018 (edited) I was smart enough to save all those seals part numbers used when it was done , but they just aren’t handy. Sorry. Parts manual online ? Mine aren’t handy now either. Edited January 26, 2018 by moosens Link to comment Share on other sites More sharing options...
impostor Posted January 26, 2018 Share Posted January 26, 2018 No worries. I think I figured it out. I ordered what I think is the boot and bushing. Link to comment Share on other sites More sharing options...
Subieguy Posted June 7, 2018 Author Share Posted June 7, 2018 It's been 7 months since I put this topic up. Still have not found the part numbers for the transmission. My Brat is just sitting till I can find the correct part numbers. Please! any member out there, do you have the part numbers so I can buy the parts to re-seal my transmission? Thanks. Link to comment Share on other sites More sharing options...
skinny664521903 Posted June 10, 2018 Share Posted June 10, 2018 (edited) The subaru FSM says to use liquid gasket maker for the oil seals. Edited June 10, 2018 by skinny664521903 Link to comment Share on other sites More sharing options...
