Jaysus Posted January 7, 2018 Author Share Posted January 7, 2018 Talking about my ea81 Link to comment Share on other sites More sharing options...
Twitch de la Brat Posted January 7, 2018 Share Posted January 7, 2018 Ok so I went to drain the oil to see what it was looking like and a spoob ton of water came out ! Wtf Leave the hood up and aircleaner off in a rain storm? If not, headgasket time. Which, honestly, you'd need to do to get more power out of it either way. And just so you know, these engines are stupid simple and can make better power with a cam change and a little tweaking. Look at the thread I linked further up. That's my build, and after it was all said and done, I was probably no more than $800 in, with the extensive machine work and replacement parts. Twitch Link to comment Share on other sites More sharing options...
jono Posted January 7, 2018 Share Posted January 7, 2018 Buy another old Sube and see if you get lucky third time 'round? Link to comment Share on other sites More sharing options...
Jaysus Posted January 7, 2018 Author Share Posted January 7, 2018 Buy another old Sube and see if you get lucky third time 'round? Hahaha ok ok I deserve that Link to comment Share on other sites More sharing options...
jono Posted January 7, 2018 Share Posted January 7, 2018 Just call it multi tasking Link to comment Share on other sites More sharing options...
Gloyale Posted January 7, 2018 Share Posted January 7, 2018 Ok so I went to drain the oil to see what it was looking like and a spoob ton of water came out ! Wtf popped a casting plug in one of the heads. Add water, it goes out into valve covers and down into oil. Pull the valve covers and rockers and check it out. Link to comment Share on other sites More sharing options...
jono Posted January 8, 2018 Share Posted January 8, 2018 Even worse if you just changed the oil. Wasyte of god oil. Water sinks to the bottom so comes out first, unless you have been able to mix it with heat and pressure Link to comment Share on other sites More sharing options...
Jaysus Posted January 9, 2018 Author Share Posted January 9, 2018 Nah just put new oil in it maybe a week ago. And I just did the head gaskets and put back in the freeze plug that had popped out before . Link to comment Share on other sites More sharing options...
DaveT Posted January 9, 2018 Share Posted January 9, 2018 If you have time and space, save the mixed oil in a closed container. The oil and water will eventually seperate, and you can skim the oil off the top. Link to comment Share on other sites More sharing options...
el_freddo Posted January 12, 2018 Share Posted January 12, 2018 As for your spark. Replace the coil. And the dizzy module. Last night my brumby stopped dead in it's tracks and wouldn't start up again. Though it was the module so replaced that with a new one. Still no spark. Did some testing and the coil had very weak spark if lucky to get one. Replace coil with a new one. Still no go. Finally it had to be the module, swapped it out for one I remember I had on another engine. Fired up first go and did a 120km trip loaded without a single miss or stumble. Try the coil first then the module. It seems like the failing/weak coil took out the dizzy's module with it - twice for me :/ Cheers Bennie Link to comment Share on other sites More sharing options...
DaveT Posted January 12, 2018 Share Posted January 12, 2018 If the primary winding of the coil has shorted, it would overload the module, explaining why the module failed also. Link to comment Share on other sites More sharing options...
jono Posted January 14, 2018 Share Posted January 14, 2018 As for your spark. Replace the coil. And the dizzy module. Last night my brumby stopped dead in it's tracks and wouldn't start up again. Though it was the module so replaced that with a new one. Still no spark. Did some testing and the coil had very weak spark if lucky to get one. Replace coil with a new one. Still no go. Finally it had to be the module, swapped it out for one I remember I had on another engine. Fired up first go and did a 120km trip loaded without a single miss or stumble. Try the coil first then the module. It seems like the failing/weak coil took out the dizzy's module with it - twice for me :/ Cheers Bennie you put a new module in first due to wealth of experience and not fix problem but a known good used one did? so returning new module ? planets must be aligned for those modules to fail around the world. mine failed a month ago. good used one fixed me too Link to comment Share on other sites More sharing options...
el_freddo Posted January 14, 2018 Share Posted January 14, 2018 you put a new module in first due to wealth of experience and not fix problem but a known good used one did? so returning new module? Good used one fixed the issue because I replaced the coil with a new stupidcheap one. The unknown module was then fitted and everything worked. Theory is the dead coil killed the new module. Not a dead new module. But I'll be talking with my parts guy to see what can be done - worth a try and I've been buying from these guys since I was 15! Should've asked for stocks in the store back then Cheers Bennie Link to comment Share on other sites More sharing options...
Jaysus Posted January 17, 2018 Author Share Posted January 17, 2018 I have 3 ignition coils. 2 accel pro stock 8140s . Ones brand new and the other was in the 85 RX i got . Stock one that came in the gl as well . I have a fluke 16 multimeter . How do I use it to test these things? Never used one before ha Link to comment Share on other sites More sharing options...
