Do to a series of events I no longer have a place to work on my offroad 78 brat project so I need to sell it.The final plan was to run a tube front end that would hold the engine and hang the fenders off.Then after that it was gonna have a solid front axle with 4 links and 35" tires to start with.So right now everything forward of the firewall has been cut off leaving just enough of the original structure for one bolt to hold the fenders on.I welded in some tubes into the floor to give a strong place to mount suspension to.Out back the bed has been chopped 17" and currently a ea81 rear suspension is mounted and installed to give 7" of lift.The rear fenders are cut out enough for 31" to have full travel.The plan out back was also a solid axle with 4links.I know its not much to go off on but it also comes with a phase 1 EJ22+wireing harness, a suzuki samurai transfercase,a dana 30 HP front axle and a whole bunch of various subaru parts as well as a couple of extra doors. Pics are in the thread "lift block height" but I might be able to get more up to date pics on a lunchbreak or something.
I just want someone who will finish the brat  rather than scrap it.I dont want to see it scraped because I've worked on it in some way for the better part of 3 years and I dont want to see that all that hard work turn into $20 at the scrapyard.
