Jarryjetz Posted November 21, 2017 Share Posted November 21, 2017 Greetings, to start off I have been working on this Subaru for far too long... I bought a wagon with a great condition body and motor. On the bad side a fire extinguisher went off inside the car, I knew this before buying the car, with the plan to exchange interior electrical etc. out of a 88 gl turbo wagon. Instead I put the motor into the 88 gl wagon and drove the parts car for about six months until car turned into a pile of rust. I decided to proceed with my original plan and swapped everything over to the good car. I got everything hooked up and put together and everything seems to work properly except for my no fuel/ spark problem, both relays are not getting power, and I can't seem to figure this out. I have tried jumping the relays, checked power to all fuses, new distributor and tested my coil. All is checking out fine. The car ran great before swapping it for the SECOND TIME. I am stumped on this one and would appreciate any help! Thanks Jarry Link to comment Share on other sites More sharing options...
Fish-N-Fool Posted November 21, 2017 Share Posted November 21, 2017 (edited) Double check all your snap together electric connections. I'd say one is not snapped in tight. Edited November 21, 2017 by Fish-N-Fool Link to comment Share on other sites More sharing options...
djellum Posted November 21, 2017 Share Posted November 21, 2017 check the codes on the computer. a likelyhood is a bad connection causing the comp to stay powered down. Link to comment Share on other sites More sharing options...
Turbone Posted November 21, 2017 Share Posted November 21, 2017 Jarryjetz, if you can read this you were banned by mistake (mine). Working on lifting the ban, hang in there Link to comment Share on other sites More sharing options...
jono Posted November 21, 2017 Share Posted November 21, 2017 You say relays not getting power. How have you found this? Probed the power supply for the relay s coil side? Is the relays coil side also getting earthed? Link to comment Share on other sites More sharing options...
scoobiedubie Posted November 25, 2017 Share Posted November 25, 2017 The black wire fusible link runs the engine. If it is hard and brittle, then replace it, or just replace it anyways with a soft black fusible link wire. The engine ground wire also gets hard at the body connnection. Then it loses it's ability to conduct electricity. If over 250,000 miles on car, replace the engine ground wire. The black wire coming off of the positive battery terminal and leads to the fusible link box, also gets hard and brittle at the battery end. If so then you would need to splice in a section of wire at the battery terminal end. Link to comment Share on other sites More sharing options...
