john in KY Posted November 24, 2017 Share Posted November 24, 2017 Car flashed a bunch of icons returning home from dinner last night. CEL/cruise/the letter "S"/some icon that looks like a car with 2 squiggly lines. Used a code reader this morning and the reader gets me as far has "Err" which I assume is error. Checked the same reader in my 95 and it worked as designed. What am I doing wrong or do I need a newer code reader. the one I have is at least 10 years old. Back to the 08. Went to change the shift mode (car has 3 different settings) and no-go. Remained in the "sport" mode. Link to comment Share on other sites More sharing options...
john in KY Posted November 24, 2017 Author Share Posted November 24, 2017 Went to AutoZone. #6 coil. Pulled battery. Lights out. Anyone recommend a good scan tool? Link to comment Share on other sites More sharing options...
wtdash Posted November 24, 2017 Share Posted November 24, 2017 the 'squiggly' lines is usually traction control - Owner's Manual will confirm. That generally does indicate an issue w/the Transmission-side. Simple 'CEL' code readers would not likely read those anyway. 2008 is probably CANBUS...although I thought the OBD2 scanners still worked....may b not so much? Search online for a CAN BUS reader or see if you can find the manual for yours to verify. No sure about 'what' would cause your issue.... Did you drive thru a snowstorm? A big puddle? Go 'muddin''? Just wondering if something got on one of the wheel ABS sensors, etc. I'd try the battery reset....Of course, this doesn't 'fix' anything...The cause of the issue will come back. but depending on how quickly it comes back may give you a clue....but NOTE that you'll lose your radio presets and you MUST know how to re-program your keyless entry / fobs BEFORE doing this. Link to comment Share on other sites More sharing options...
brus brother Posted November 24, 2017 Share Posted November 24, 2017 Not so sure about the reprogramming of remotes. Have changed battery and never had to reprogram the remotes on my 08. I use a cheapo scanner to scan and reset my 05 and 08 like the $15 one linked below: LINK It plugs into the terminal and doesn't require a computer or smart phone. Simple to use. I have gotten error codes when I turned the key to the on position Before attaching the reader. Correct sequence: key off/attach scanner tool/key to on position/hit scan button Link to comment Share on other sites More sharing options...
Fairtax4me Posted November 25, 2017 Share Posted November 25, 2017 Traction control and cruise are disabled when the CEL comes on, so those lights turn on as well. Sounds like you just need a newer code reader. Look into the Torque app if you have a non-iPhone. 1 Link to comment Share on other sites More sharing options...
1 Lucky Texan Posted November 25, 2017 Share Posted November 25, 2017 will his 08 do the 'native' code display routine? (agree on the canbus being likely reason old reader won't connect) Link to comment Share on other sites More sharing options...
john in KY Posted November 25, 2017 Author Share Posted November 25, 2017 (edited) Ordered new code reader and from the photo noticed the plug has 16 pins whereas my old reader has far fewer. Will know something next week when the new one gets here. Edited November 25, 2017 by john in KY Link to comment Share on other sites More sharing options...
