I have a write up that details everything you need to know.
95 EJ22 automatic intake has EGR
If you don’t have emissions and don’t care about a benign check engine light you can install any 95-98 EJ22 intake with non EGR and just ignore it. That’s what I do on purpose just to simplify the engine bay.
If the engine has EGR but the intake doesn’t then just cut a small block off plate and bolt it on to the head to seal it or take the EGR tube, thread it into the head, cut it, and crimp and weld it shut.
I make a block off plate out of thin metal, use sealant, and bolt it on.
