Jakethewhite Posted November 29, 2017 Share Posted November 29, 2017 87 subaru gl 1.8 FI 4x4 wagon This is the exact same situation that was found on http://www.ultimatesubaru.org/forum/topic/118912-88-dl-starts-then-dies/ But was never solved. Same ecu codes: 6 repeated and that's it. It will start up and then immediately die. If I try to press on the gas then it dies quicker. Checked fuel pump and it is good. I checked it at the fuel connection and it spews out gas. This is the thing that looks like a carb but isn't because the car is fuel injection. I Link to comment Share on other sites More sharing options...
Jakethewhite Posted November 29, 2017 Author Share Posted November 29, 2017 Idk what else to do I've checked all fuses and they are good and everything Link to comment Share on other sites More sharing options...
DaveT Posted November 29, 2017 Share Posted November 29, 2017 A pressure gauge would be more informative regarding the fuel pressure and supply rate. The cts can cause trouble with cold running, among other things. Link to comment Share on other sites More sharing options...
Subasaurus Posted November 29, 2017 Share Posted November 29, 2017 remove a spark plug and see if the spark is extremely weak when cranking, mine would stay running for about 10-15 seconds and then die, let the vehicle "cool down" even though nothing warmed up for a few minutes and it would restart and run for a few seconds, then die again, turned out to be the distributor, the square sensor that reads the disk spinning around, also known as an early crank sensor of sorts. hope this helps. Link to comment Share on other sites More sharing options...
alexbuoy Posted November 30, 2017 Share Posted November 30, 2017 how’s your MAF. mine was plugged would only run for a second Link to comment Share on other sites More sharing options...
