Naked Buell Posted December 9, 2017 Share Posted December 9, 2017 So hey guys, you helped me figure the two plugs off the tranny, reverse and neutral switch, and now maybe someone can help me identify which is which. Looking at the side of it, one is closer to the engine and one closer to the driveline. So does anyone know? I have found one pic in my manual that says one closest to engine is reverse? Is that right??? Thx guys Link to comment Share on other sites More sharing options...
Gloyale Posted December 9, 2017 Share Posted December 9, 2017 Yes the front one, a little lower than the other is reverse Link to comment Share on other sites More sharing options...
Naked Buell Posted December 10, 2017 Author Share Posted December 10, 2017 Okay, so I decided to do a continuity test with the tranny swithches and I am not getting nothing, in reverse or in neutral from either switch. I even have a extra 5 speed ej tranny out of a car and tested that, still nothing. Am I doing something wrong here?? How are the switches working if I can't get continuity?? Link to comment Share on other sites More sharing options...
Fairtax4me Posted December 10, 2017 Share Posted December 10, 2017 What setting did you use on the meter? IIRC those switches are resistive and using the continuity setting may not show continuity due to the resistance of the switch. Link to comment Share on other sites More sharing options...
Naked Buell Posted December 10, 2017 Author Share Posted December 10, 2017 Maybe so. I was using a Fluke T5-1000 continuity ohm test. How should I test them? Link to comment Share on other sites More sharing options...
Fairtax4me Posted December 10, 2017 Share Posted December 10, 2017 Just dug a spare out of a parts box and tested it and these are actually NOT resistive switches. I'm thinking maybe it was Nissan that uses those, can't remember off hand. They should read close to 0 ohm when you push the plunger. Poor connection maybe or for some reason your meter just isn't reading properly. Link to comment Share on other sites More sharing options...
Naked Buell Posted December 11, 2017 Author Share Posted December 11, 2017 The neutral switch is the furthest back switch, while the reverse is towards the front, for any who don't know. Link to comment Share on other sites More sharing options...
