5000fingers Posted December 9, 2017 Share Posted December 9, 2017 My 2001 Outback is the same green color that I see on half of the Outbacks around here. I have a spot that I'd like to do a little touchup painting. What is a good source for the original color spray paint? Link to comment Share on other sites More sharing options...
gbhrps Posted December 10, 2017 Share Posted December 10, 2017 Any auto body shop supplier, and many auto parts stores as well, can get the paint code from your car's manufacturer's sticker (usually driver's door frame at the B pillar) and mix up the paint for spraying, or even put it into spray cans for the DIYer. I've had it done several times. But be prepared for colour mismatch on your existing paint that has had 17 years in the sun and the elements and has faded. Some paint shop suppliers can use a colour scanner to more closely match the true colour that your car is now, before they mix it up. Good Luck! Link to comment Share on other sites More sharing options...
mikec03 Posted December 10, 2017 Share Posted December 10, 2017 I've used automobivetouchup for years. Always a good match on 5-6 different cars. http://www.automotivetouchup.com/ 1 Link to comment Share on other sites More sharing options...
Mike104 Posted December 12, 2017 Share Posted December 12, 2017 On 12/10/2017 at 6:52 PM, mikec03 said: I've used automobivetouchup for years. Always a good match on 5-6 different cars. http://www.automotivetouchup.com/ Definitely a good choice Link to comment Share on other sites More sharing options...
idosubaru Posted December 12, 2017 Share Posted December 12, 2017 The Napa in my town can mix up according to your paint code. Call around until you find a store that does the same. You can also order them online. Same with two stage clear coat. Comes in a can. A mechanism punctures the separate checkials inside and mixes them into a hardening clear coat that’s a single use can. Probably only need that if you’re doing the bumper or hood where bugs and stones at 80mph aren’t going to treat cheap paint well. Link to comment Share on other sites More sharing options...
