Power loss, please help.
I have a 1985 4wd Turbo RX manual trans Subaru.  I am not sure why I can't get the car over 4k rpm and the turbo light comes on after 3k but kinda flickers, could I get some help understanding why the cars lacks power.  I have great idle, easy cold/hot start and trouble with climbing hills and speed above 45 mph.  :(
Ok, I have inspected for boost leaks and see nothing wrong. I thought it might be the restrictor cat but exhaust comes out strong at idle and there is no cat beyond the restrictor one on my car, it was removed with new exhaust pipe work. Is there anything that makes the car cut power that I should look into?
4WD Turbo RX, on 10 Dec 2017 - 12:24, said:
 I can't get the car over 4k rpm :(
Runs smooth up to 4k?
I`d say plugged exhaust.
Try it w/the downpipe loosened off or put a pressure gauge in the O2 sensor hole.
Your car should easily rev to 4k in neutral even with a SEIZED turbo.
Edited by naru
  • Like 1
I had an 85 or better known as the three plug , flapper afm Series One
There is two black vacuum or boost pressure actualy switches or should be, RHS tower. One drives the boost light, the other is supposedly to kill fuel or is it ignition at an over boost pressure I dont know what pressure. Maybe disconnect and see if get same problem?
Have you found the ECU attached to steering column? Factory anyway has a red LED you should be able to see through a peek a boo hole n under steering plastic trim panel or between it and column in the dark
I also got something like this from a the 20 year old coil, then again a year later on the chinese made bosch laminate style no oil can type coil. Went genuine 22433AA041 and never had problem again
Fuel pump[s usually cause problems just on boost as they start to fail. I would rule that out at the moment but worth checking on a pressure gauge while driving
Edited by jono
GO Turbine! Great suggestion.
Why does OP call it a restrictor cat?
What did you do to find it was problem?
Whadja do to fix?
The car I have came with 2 catalytic converters, the first hangs vertical from the turbo and then there is a 2nd under the car just past the transmission. The 1st catalytic converter is the restrictor catalytic converter, it was plugged.
  • Like 1
