EA82 dicconected now fast idle!
jono
My egr has not done much work since installed in a clean condition
15000 km if that
Just disconnected it to see if it was cause of lumpy idle and started up first time today, drove off to find once warmed up she idles about 1200 - throttle body vac port plugged.
So connected egr again to find idle back to 800
Something dicky in the egr me thinks
  • Like 1
Egr delete did not give me any noticeable power gains but now have lurvley smooth idle even down to about 600 rpm
Something not had since this engine went in this beast after sitting around for a bit
Well, getting best fuel economy so far...see if it continues, or balances out next fill :D
If you can google the john bennet cooling system, he was doing radical things with EGR, like porting them out to increase its contribution at the right moments gaining economies, addressing cavitation caused by water pumps, recirculating coolant bypassing the radiator and getting cooler running systems, thermostat in the lower hose like EJs, and gaining power increases
