jono Posted December 16, 2017 Share Posted December 16, 2017 Subaru used to specify the capacity of the radiator in the cooling system section with the EA81 and forgot to include it in factory manual for the EA82 likely coz it was less Anyone have an ej factory manual with that spec please? Curious to know if legacy radiators greater than ea81 twin cote 1.2 litres Thanks Link to comment Share on other sites More sharing options...
GeneralDisorder Posted December 16, 2017 Share Posted December 16, 2017 Nearly all EJ's are about 1.5 gallons system capacity. 6 cylinder models tend to be closer to 2 gallons. Capacity isn't all there is to cooling efficiency. It's all about surface area. More modern radiators have smaller tubes and higher fin density. GD Link to comment Share on other sites More sharing options...
jono Posted December 16, 2017 Author Share Posted December 16, 2017 Yep thanks but I am after the radiator capacity not the cooling system capacity thanks so far Link to comment Share on other sites More sharing options...
GeneralDisorder Posted December 16, 2017 Share Posted December 16, 2017 They don't publish that AFAIK. You will have to test. GD Link to comment Share on other sites More sharing options...
Fairtax4me Posted December 17, 2017 Share Posted December 17, 2017 Radiator capacity for a phase 1 EJ is around 3 quarts. They vary slightly depending on model and engine size. Link to comment Share on other sites More sharing options...
jono Posted December 17, 2017 Author Share Posted December 17, 2017 Quart being quarter of a US gallon of four litres. My gallons are 4.54 litres. Three litres in an ej radiator is a lot! Thanks for your efforts Link to comment Share on other sites More sharing options...
