Still have a battery drain, ideas?
Some test info: '96 Legacy, EJ22 engine, key off & removed
mA meter between -battery post and post clamp.
65 mA steady current after 1 minute (to let ECU settle down)
= 1.5 Ah/day = 47 Ah/month
Group 35 batteries used in the '96 typically list ~ 40 Ah capacity, so could discharge battery in a month...
Leaving my UltraGauge (OBDII viewer) plugged in doubled the draw - apparently it keeps checking to see if the key has been turned on yet - so only 2 weeks to discharge battery.
Got bitten when I didn't start the car for several weeks followed by a sub-zero cold snap (discharged batteries freeze easily)...
  • 5 weeks later...
Wanted to update to possibly save someone else the headache in the future.
You definitely NEED BOTH wires going to the alt (constant 12v+
AND the "dummy light" wire
). 12v+ constant *can* be attached to the right-side (if looking down at engine from front of car orientation) terminal and will allow alt to charge but needs a key-on activated relay to avoid draining battery at engine off. After getting both wires in proper orientation and connected, no drain and car can sit w/o being dead overnight.
My mistake for thinking they could be run as a 1-wire set up as-is. Connector plug was cut to get the Tribecca alt to work before, and once reverting back to the factory-style alt, saw it was charging with right-side getting fed 12v+ constant and assumed it was correct. Since the drain can take days to leave battery dead to months in warmer weather, and alt was testing OK with good diodes; like chasing a group of wild turkeys.
Edited by Bushwick
  • Like 1
