dp213 Posted December 23, 2017 Share Posted December 23, 2017 Is there a difference between the 97, 98, and 99 2.5 blocks? I am doing a frank and need to know what head gaskets to get. I think the block is 99 and I know the heads are 93. Link to comment Share on other sites More sharing options...
Fairtax4me Posted December 23, 2017 Share Posted December 23, 2017 (edited) edited: was thinking of wrong block Not the one with flat top pistons Edited December 24, 2017 by Fairtax4me Link to comment Share on other sites More sharing options...
rocketman Posted December 23, 2017 Share Posted December 23, 2017 My 99 forester is single can. Link to comment Share on other sites More sharing options...
rocketman Posted December 23, 2017 Share Posted December 23, 2017 Sorry,single cam Link to comment Share on other sites More sharing options...
GeneralDisorder Posted December 23, 2017 Share Posted December 23, 2017 That combo doesn't work. 99 single cam has flat top pistons. Compression will be up near 12 and it will detonate like crazy. You need 97 to 99 DOHC pistons. GD Link to comment Share on other sites More sharing options...
dp213 Posted December 24, 2017 Author Share Posted December 24, 2017 So with the 99 block, just use the 25d head gaskets from subaru Link to comment Share on other sites More sharing options...
GeneralDisorder Posted December 24, 2017 Share Posted December 24, 2017 (edited) On 12/24/2017 at 3:03 AM, dp213 said: So with the 99 block, just use the 25d head gaskets from subaruMy compression figure IS using that gasket. Which makes it even more prone to detonation because the quench will be obscenely large. This is not a good candidate for a performance build. It will pull so much timing you won't make any power. And will likely melt a piston eventually. GD Edited December 24, 2017 by GeneralDisorder 1 Link to comment Share on other sites More sharing options...
dp213 Posted December 24, 2017 Author Share Posted December 24, 2017 I'm not doing a power build. I need a motor and have the parts in my garage. So 25d gaskets? Link to comment Share on other sites More sharing options...
GeneralDisorder Posted December 24, 2017 Share Posted December 24, 2017 On 12/24/2017 at 5:25 AM, dp213 said: I'm not doing a power build. I need a motor and have the parts in my garage. So 25d gaskets? It won't be good. 11.5:1 compression will not last long. You will break and melt pistons. This IS NOT a workable combination with pump gas. It doesn't have enough cam or quench to run without hurting itself. GD Link to comment Share on other sites More sharing options...
dp213 Posted December 24, 2017 Author Share Posted December 24, 2017 This is a 99 dual can block Link to comment Share on other sites More sharing options...
dp213 Posted December 24, 2017 Author Share Posted December 24, 2017 Cam Link to comment Share on other sites More sharing options...
dp213 Posted December 24, 2017 Author Share Posted December 24, 2017 And no offense, but I didn't ask for anything more than an answer to a specific question. And the answer, i thought, would be a pretty easy yes or no. Link to comment Share on other sites More sharing options...
rocketman Posted December 24, 2017 Share Posted December 24, 2017 I think you need to use newer turbo head gasket Gd talked about in other post,number ending in 604. Link to comment Share on other sites More sharing options...
GeneralDisorder Posted December 24, 2017 Share Posted December 24, 2017 Dual cam block will be fine. Use the 25D gasket for 10.5 compression. Not a good gasket for longevity but will run fine. GD Link to comment Share on other sites More sharing options...
dp213 Posted December 24, 2017 Author Share Posted December 24, 2017 Cool. Thank you. It of needs to last till summer. Link to comment Share on other sites More sharing options...
idosubaru Posted December 24, 2017 Share Posted December 24, 2017 On 12/24/2017 at 5:38 AM, dp213 said: And no offense, but I didn't ask for anything more than an answer to a specific question. And the answer, i thought, would be a pretty easy yes or no. We glanced over your first question about the differences between 97-99 blocks, otherwise we would have gotten there quicker. It would have been simple but it took you 4 replies to find out which block you had. A "99 block" could be two different engines - a Phase II EJ25 (99 foresters and imprezas) or a Phase I EJ25 (99 legacy or outback). all this happens in 9 seconds in person and drags on online. Link to comment Share on other sites More sharing options...
