WaggyBrown Posted December 25, 2017 Share Posted December 25, 2017 (edited) Does anyone here know how to take apart the pistol grip shifter on an 85 xt turbo? The four wheel works, the light works. Only problem is it’s almost like the old owner spilled a juice box in there and it won’t pop back out when I push it in. I’ve just been using a blade to wiggle it back up. Any pointers to get this taken apart? The holes on either side of it don’t unscrew, and neither does the one in the front. I don’t want to clean it with an alcohol swab and ruin something electrical. It’s thepistol-grip shifter with the interlock release button. Edited December 26, 2017 by WaggyBrown Link to comment Share on other sites More sharing options...
john in KY Posted December 25, 2017 Share Posted December 25, 2017 Should be 2 small screws, one on each side of the handle/stem. Remove screws and the outer part of the shifter can be pull upwards. Link to comment Share on other sites More sharing options...
Loyale 2.7 Turbo Posted December 26, 2017 Share Posted December 26, 2017 ... I don’t want to clean it with an alcohol swab and ruin something electrical. Computer's / Electronics Cleanser in Spray, is Safe to be used there. An Example: ~► http://www.microcenter.com/product/363671/Contact_Cleaner Disassembling the parts for cleansing is the idoneus way, but it might remove the sticky gunk without disassembling. Kind Regards. Link to comment Share on other sites More sharing options...
impostor Posted December 27, 2017 Share Posted December 27, 2017 Manual I assume? There is a little screw on the front that holds the button to the handle. I used a number 1 Phillips bit without a handle. It's not very tight. You can then pop the switch up just enough to work a qtip around in there. Don't force it up too far. I also took various grits of sand paper to remove some material from the button. If yours is like mine, some of the binding comes from the fact that the handle's rubber has lost some of its shape over the years. Link to comment Share on other sites More sharing options...
