PMA Posted December 25, 2017 Share Posted December 25, 2017 I just bought my first Subaru. It is a 1992 Loyale with 148K on her. I want to use her as a daily work vehicle. I can't explain it but I like the way the SW looks. It had some electrical issues with the head and tail lights but a bad ground repair fixed that. It runs good but the check engine light comes on when the engine warms up. Can anyone lead me to a sight that can tell me how to check and read codes? Link to comment Share on other sites More sharing options...
Len Dawg Posted December 26, 2017 Share Posted December 26, 2017 Under the steering wheel take off the lower panel and to the left is the on-board diagnostics red light beeping at you here'sthe codes???? Yep any all of these apply to the Loyale as well. 1988-94 SPFI EA82s are all the same -- 1988 and Later Models With Single-Point Fuel Injection -- CODE PROBABLE CAUSE 11 Crank Angle Sensor or Circuit 12 Starter Switch or Circuit 13 Crank Angle Sensor or Circuit 14 Fuel Injector - Abnormal Output 21 Coolant Temperature Sensor or Circuit 23 Air Flow Meter or Circuit 24 Air Control Valve or Circuit 31 Throttle Sensor or Circuit 32 Oxygen Sensor or Circuit 33 Vehicle Speed Sensor (VSS) or Circuit 34 EGR Solenoid or Circuit 35 Purge Control Solenoid or Circuit 42 Idle Switch or Circuit 45 Kick-Down (Detent) Relay or Circuit 51 Neutral Switch Continuously in the On Position 55 EGR Temperature Sensor or Circuit 61 Parking Switch or Circuit 1 Link to comment Share on other sites More sharing options...
Len Dawg Posted December 26, 2017 Share Posted December 26, 2017 And ya have to have plug together the Green connectors under the hood on driver side at the firewall. Link to comment Share on other sites More sharing options...
DaveT Posted December 26, 2017 Share Posted December 26, 2017 If the code is a current problem, CEL is on. you don't have to do the green connectors step. Just read the LED. Link to comment Share on other sites More sharing options...
DaveT Posted December 26, 2017 Share Posted December 26, 2017 there are also a number of things you are going to want to go through and be aware of dealing with one of these nearly 30 year old cars, especially if you intend to rely on it. Link to comment Share on other sites More sharing options...
PMA Posted January 8, 2018 Author Share Posted January 8, 2018 Thanks for the help Guys. It ended up being the oxygen sensor. Now I have another problem. It snowed and the roads got icy. I took the Loyale out for a spin and she was all over the road. I got her up on a lift and it looks like the bushing at the top of the rear differential is falling apart. I looked on line and called Subaru. The bushing is not available any more. Does any body know where I could find some vintage parts? Link to comment Share on other sites More sharing options...
DaveT Posted January 8, 2018 Share Posted January 8, 2018 You need 4 all season tires with similar mileage = decent tread on them. They don't have to be as exact as for AWD, but if you end up with 2 pairs that are very different OD, the handling can be weird in 4WD. That bushing probably had nothing to do with being all over the road. Probably have to find a used one, look for a mod shop that has something close / modifiable to fit. If the alternator is original, it will need a new brush soon. Link to comment Share on other sites More sharing options...
el_freddo Posted January 10, 2018 Share Posted January 10, 2018 That bushing probably had nothing to do with being all over the road. Agreed. Poor wheel alignment will also do it, or a heavy foot and someone with no idea of how to control a 4wd slid/power slide... Cheers Bennie Link to comment Share on other sites More sharing options...
robm Posted January 10, 2018 Share Posted January 10, 2018 Also, 4WD on tight corners = spin out. The back wheels are forced to go as fast as the fronts, and they actually trace a track that is tighter than the fronts, so they should be going slower. This will cause you to spin out, if you are not aware of the possibility. 1 Link to comment Share on other sites More sharing options...
