ignition module spacer heatsink
jono
Just about to start a little bench test for efi fuel pumps and fpr andfound the guts of a ddistributor of the two pin type for.ea81 and early ea82 cacarb
Instead of tubular spacers to mount the module it has a one piece alloy cast spacer that may also be a crude heatsink.
Anyone know what models this alloy spacer started with?
It may just be an improvement on the two loose tubes for assembly.
A heatsink stuck to the module underside may give longer module life??
