2003 Baja Rear Camera Install?
BajaBoogie77,
I suspect that the route would be as follows: center dash, across the underside of the dash to the kick panel, under the door thresholds front and rear to the interior flapper vents on the rear wall of the cabin at the corners (that's where they are on most cars and trucks. Pull the cargo area back panel under the rear windshield to access the flapper valves, pull the side cargo panel to the tailgate rubber gaiter  that feeds wiring to the license plate lights and the camera.
You may find a wiring harness from the rear of the cabin back to the tailgate to follow, who knows. I've never owned a Baja, but this should be pretty close.
