BajaBoogie77 Posted December 27, 2017 Share Posted December 27, 2017 Trying to figure out the best way to run the wires from the camera and the reverse light to the radio. Anyone found a good method? Link to comment Share on other sites More sharing options...
gbhrps Posted December 30, 2017 Share Posted December 30, 2017 BajaBoogie77, I suspect that the route would be as follows: center dash, across the underside of the dash to the kick panel, under the door thresholds front and rear to the interior flapper vents on the rear wall of the cabin at the corners (that's where they are on most cars and trucks. Pull the cargo area back panel under the rear windshield to access the flapper valves, pull the side cargo panel to the tailgate rubber gaiter that feeds wiring to the license plate lights and the camera. You may find a wiring harness from the rear of the cabin back to the tailgate to follow, who knows. I've never owned a Baja, but this should be pretty close. Link to comment Share on other sites More sharing options...
