allavalle62 Posted December 29, 2017 Share Posted December 29, 2017 (edited) oil leaking down bottom of both heads, changed cam seals and still leaking . Looks like maybe leaking from heads, but does not need to be running to leak. any help would be great. This is a 1997 legacy outback. Edited December 29, 2017 by allavalle62 Link to comment Share on other sites More sharing options...
dp213 Posted December 29, 2017 Share Posted December 29, 2017 Valve cover gaskets? Link to comment Share on other sites More sharing options...
wtdash Posted December 29, 2017 Share Posted December 29, 2017 +1 on VC gaskets...those half-moons can be a pain to seal. Link to comment Share on other sites More sharing options...
idosubaru Posted December 29, 2017 Share Posted December 29, 2017 VCG's, spark plug tube orings/gaskets, cam seals. maybe the cam seals are leaking again, check to see. Link to comment Share on other sites More sharing options...
msmithmmx Posted December 31, 2017 Share Posted December 31, 2017 I had an issue like this. Take a look at the back of the engine. See if the rear cam plugs are leaking. They will drip down the rear of the engine making it look like the heads are leaking. Link to comment Share on other sites More sharing options...
