1998 outback won't start in park
Mine is doing the same thing, but the large solenoid to disengage park quit working (at exactly the same time), so that means getting it out of park, then popping in neutral. Thankfully, neutral starting has been reliable.
With that said, 1 time since this started happening, the solenoid worked and it actually started in park. I've tried manually working the solenoid with key set to crank, and no luck. Unsure if coincidence or not.
