Reinstalling 2005 Impreza engine. Didn't do the engine removal. The top fuel line disconnect not clicking back in to the fuel line..The fuel  line disconnect below the upper fuel line is clicking back in. Is the plastic piece in the disconnect a replaceable piece or could the disconnect be replaced with a gas hose clamp.? Also the ac line seems to run directly above the oil filler cap which makes it difficult to remove the oil fill cap. Since I didn't do the the engine removal not sure where the ac line is supposed to be relative to the oil fill spout and cap.
Edited by steve56
Fuel lines I just hack off those stupid disconnect fittings and install a clamp like old school Subarus that have zero failure rates and more practical.
AC line maybe look up pictures online.
Yes I thought the older Subarus just used hose clamps on the fuel lines.Thanks for verifying. The ac metal line must have gotten bent down from the ac pump being disconnected.Is it safe to bend it back without causing a freon leak in metal hose?
You can bend it holding the metal line only.  Don't hold it by the part where rubber crimps into the metal it would cause leaks, ask me how I know :D
great call on the crimp - that is the most common failure, and the oring, but that’s an easy and nearly free fix.
