tonyarmstrong Posted January 6, 2018 Share Posted January 6, 2018 WILL WHEELS FROM A 17 FORESTER FIT A 17 LEGACY? THANKS! Link to comment Share on other sites More sharing options...
dfoyl Posted January 6, 2018 Share Posted January 6, 2018 PCD is the same. Offset should be the same. Size may be an issue if your Forester wheels are smaller than your Legacy, as calipers may not clear smaller wheels - but I'd assume you have 16s or larger on the Forester and there's only one Legacy I know of that needs 17's (Legacy GT). Link to comment Share on other sites More sharing options...
wtdash Posted January 6, 2018 Share Posted January 6, 2018 No...they have different Bolt Pattern: 2017 Forester is still 5x100/ 5x4"; 2017 Legacy is 5x114.3/ 5x4.5" Per Tire Rack (and probably owner's manuals). Link to comment Share on other sites More sharing options...
Numbchux Posted January 8, 2018 Share Posted January 8, 2018 (edited) PCD is the same. Incorrect. wtdash is correct that the Forester stuck with 5x100, where the Legacy/Outback line switched to 5x114.3 in 2015 They will not bolt up. Also, FYI. All Legacies have at least 17s these days, some with 18s. Edited January 8, 2018 by Numbchux Link to comment Share on other sites More sharing options...
