misfire on number 1 cylinder '06 Tribeca, H6
I verified you guys are right. Gotta bring car, new ECU, and key fobs to Subaru dealer to get it all programmed. Can't plug and play with ECUs, at least not on the '06 Tribeca. Can't just grab another ECU and throw it in and expect the car to run.
I have checked wiring extensively but didn't check for voltage on the ground pin for injector 1 at the ECU. Just go from the ground pin to ground, correct? Won't I have some voltage drop across the injector?
  • Like 1
Hello. You have completed some good troubleshooting.  I am not a believer in coincidences. If you did not have this issue before the head gasket work then the odds are less then 1% that you have a ECU problem post swap.  You mentioned that you have 130 psi in that cylinder.   That is low.  I searched around and you should be around 185. Google "low compression and misfire".  Check something like this out
http://www.subaruoutback.org/forums/66-problems-maintenance/157514-p0304-help-tried-everything.html
In a properly operating circuit you'll see the voltage drop Only if the ECU is grounding the circuit. With key On,You should see 12v at both pins on the injector (plugged in) and you should have 12v at that injector pin on the ECU.
Voltage only drops across the load when a ground is present. With no ground, voltage will remain the same all the way to the end of the circuit, or the point at which the circuit is open.
So if/when the ECU grounds that injector circuit, the voltage will drop to near 0.
If you have 12v reaching the ECU with the key On, start the engine and see if that voltage fluctuates with the engine running. (Presumably the ECU will be pulsing that injector ground to spray the injector) Steady voltage at this point will confirm the ECU is bad.
If you have no or low voltage reaching the ECU, that will mean a break or poor connection in the wiring.
Ok, now as a final check to rule out a short to voltage, while checking voltage at the ECU (key on) Unplug the number 1 injector. Voltage should drop to 0.
If voltage stays up there is a short to voltage in the harness.
It's not easy for an injector driver circuit to burn out unless there is a short directly to supply voltage (no load, thus high current passing through the circuit) or an internal fault in one of the components in the circuit. What you don't want is to install a new ECU and have the same problem because of an issue in the harness that caused the old one to be damaged.
So with the injector unplugged if 0v showing on the meter, wiggle the major parts of the wire harness all around and make sure the voltage doesn't jump up instantaneously, due to a temporary short.
  • Like 1
  • 2 weeks later...
Update: Found a used ECM on ebay. Took car, key fobs and ECM to a dealer. Dealer reprogrammed new ECM. VOILA!! Problem fixed!
So apparently this was that 1% probability that the ECM failed shortly after the head gasket work and the two problems were unrelated.
Definitely goes against reason, but hey, it's fixed now...
Thanks to you all for all the help!
good job tracking this down and thanks for the feedback.
i don't think it's likely - but curiously wonder what's the pro's would say to whether or not a long term misfire (caused by the ECU) could instigate, precipitate, or exacerbate headgasket failure?
I have over 200 miles post ECU swap, and no problems. Hope it stays that way :). I got a used ECU off ebay for $145 and it cost $115 to have the dealer program it.
Not as expensive as it could have been. I was glad I didn't diagnose it with a credit card, as some shops would have done...
Following some info on these forums, I boiled my diagnosing for a misfire down to the following steps:
1. Verify spark
2. Verify fuel and air
3. Verify compression
Once I saw the injector wasn't working (but all the others were), I then:
1. Checked for power at the injector
2. Checked for a pulse with a noid light
3. Gave the injector 12 V while engine was running and the misfire went away.
4. Traced the wiring harness and connections back to the ECU.
5. Tested the pulse coming out of the ECU to verify no injector pulse.
Hope this can be helpful to someone else...
  • 1 year later...
I had number 1 missfire..
I used an led light, you can see it blink, looking closely. Hot to battery, negative to injector wire. (Led polarity matters)Tested with working injector,  then number 1, was no blinky
Two things.. adding power should not and will not open injector, adding ground would..  but don't,  you're shorting ecm.
Instead of buying new ecm, solder board where injector wire pin is on it..
They wires all have black sheathing in last plug, easy to find..
Much cheaper, fixed as soon as you melt  cold solder joint, slit second.
Update it was actually this IC. SOLDER all connections.
Edited by Druboi
Was wrong
  • Like 1
  • 4 years later...
2006 Tribeca H6, 215k miles, Fixed my Cylinder 1 misfire by soldering IC608 as shown in the above post.  First checked pin to board solder joint, then traced to this IC that grounds each injector.  Please don't bake your entire board.  There's also a video on youtube where Black Horse Repairs completely removes the chip to clean and install with new solder.  Again, very risky, just use a fine solder tip and reflow only the pins of this chip.  Post something after this if anyone even still works on these cars!
Edited by MPG Subaru
  • Like 1
  • Thanks 1
