Leveling front of 84 with factory adjustable struts
New to the forum, tried using the search function. But I’ve had this 84 since August of 17’ did the Weber swap (EA81) and I want to level the front of it is it just as simple as turning the adjusters in the struts out? Need to replace wheel bearing on RF, as well as the outer tie rod end on same side.
Thanks in advance!
