Fish-N-Fool Posted January 18, 2018 Share Posted January 18, 2018 My 93 Loyale doesn't put out good heat, it blows lukewarm air at best. It has good flow through the heater core as both hoses get very hot. Does anyone have an expanded view of the heater box or have any info on how the heater door works and where it's at? This is a 5sp with AC 4x4 wagon Then you turn the heat off with the switch it blows COLD turn the heat on it blows warmish. I suspect the heat door is not opening properly, any way to check that? Link to comment Share on other sites More sharing options...
DaveT Posted January 18, 2018 Share Posted January 18, 2018 The temperature lever / slider mechanically moves a blend door that directs the air through the heater core or around it. 1 Link to comment Share on other sites More sharing options...
idosubaru Posted January 18, 2018 Share Posted January 18, 2018 another possibility is to clean out the heater core. pull both hoses and run water through it. Link to comment Share on other sites More sharing options...
MR_Loyale Posted January 19, 2018 Share Posted January 19, 2018 You can pull the hoses off the firewall and use an air compressor to pulse air blasts through it. This helps unclog the gunk 1 Link to comment Share on other sites More sharing options...
