Rooster2 Posted January 18, 2018 Share Posted January 18, 2018 My heater fan motor will only operate on fastest speed. I think the problem must be in resistor cluster. Where is this located?? Is it built into the HVAC controls in dashboard?? Thanks for any help. Link to comment Share on other sites More sharing options...
1 Lucky Texan Posted January 18, 2018 Share Posted January 18, 2018 maybe number 17 here; http://opposedforces.com/parts/legacy/us_b11/type_45/climate/cooling_unit/illustration_1/ not sure if I have the right model, probably similar though. Link to comment Share on other sites More sharing options...
Rooster2 Posted January 18, 2018 Author Share Posted January 18, 2018 On 1/18/2018 at 6:02 PM, 1 Lucky Texan said: maybe number 17 here; http://opposedforces.com/parts/legacy/us_b11/type_45/climate/cooling_unit/illustration_1/ not sure if I have the right model, probably similar though. Thanks Texan for the link. I am not sure what I am seeing on the link diagrams, but looks like it may be built into the dashboard HVAC unit. I happen to have a replacement unit handy, so may install that unit to see if it cures my problem. Thanx! Link to comment Share on other sites More sharing options...
1 Lucky Texan Posted January 18, 2018 Share Posted January 18, 2018 (edited) On 1/18/2018 at 6:20 PM, Rooster2 said: Thanks Texan for the link. I am not sure what I am seeing on the link diagrams, but looks like it may be built into the dashboard HVAC unit. I happen to have a replacement unit handy, so may install that unit to see if it cures my problem. Thanx!I think that's behind the glove box - but toward the centerline of the car. Hopefully, someone else will respond. Edited January 18, 2018 by 1 Lucky Texan Link to comment Share on other sites More sharing options...
idosubaru Posted January 18, 2018 Share Posted January 18, 2018 what he said - should be #17, all the ones i've ever seen are accessed in the lower passengers footwell, other than a cover or something i think it's easily accessible. i feel like one model i've done i had to remove the blower motor to get to it. other than XT6's i've only done like 1 of each model i've encountered so they all kind of run together. but none have ever been hard or more than just cover or something to get to. Link to comment Share on other sites More sharing options...
Rooster2 Posted January 18, 2018 Author Share Posted January 18, 2018 Thanks guys for the advise. As I posted earlier, I have an HVAC unit that I can install. It appears looking through holes in the plastic housing, that there are copper windings attached to the fan speed rotary switch shaft. I can swap it in to see if it fixes the problems, if not then I search behind the glove box - but toward the centerline of the car as advised. Thanx! Link to comment Share on other sites More sharing options...
Gloyale Posted January 18, 2018 Share Posted January 18, 2018 On 1/18/2018 at 6:58 PM, Rooster2 said: Thanks guys for the advise. As I posted earlier, I have an HVAC unit that I can install. It appears looking through holes in the plastic housing, that there are copper windings attached to the fan speed rotary switch shaft. I can swap it in to see if it fixes the problems, if not then I search behind the glove box - but toward the centerline of the car as advised. Thanx! The resistor block is in the Ducting, between the Blower and the Evap core. rectangular 4 pin plug. IT's in the ducting to keep the resistor cool from air movement. NOT in the switch. 1 Link to comment Share on other sites More sharing options...
Rooster2 Posted January 19, 2018 Author Share Posted January 19, 2018 Thanks to all for the help, especially to Gloyale. Your description of "The resistor block is in the Ducting, between the Blower and the Evap core. rectangular 4 pin plug", was precisely the info I needed to find one in a wrecking yard. Otherwise, I would not really know exactly what I was looking for. Resistor unit I bought was from a 98 Impreza Outback Sport, but figure the resistor unit is interchangeable with a Legacy car. Now to install it. Link to comment Share on other sites More sharing options...
djmark7 Posted January 20, 2018 Share Posted January 20, 2018 take out the glove box youll be looking right at it Link to comment Share on other sites More sharing options...
Rooster2 Posted January 20, 2018 Author Share Posted January 20, 2018 On 1/20/2018 at 12:18 PM, djmark7 said: take out the glove box youll be looking right at it Good idea..........when I pulled one from a yard, the glove box was already pulled, so made for an easy pull. I will do that later today, when it warms up a little outside. Link to comment Share on other sites More sharing options...
