iriejedi Posted January 20, 2018 Share Posted January 20, 2018 Does anybody know if a 2.5L EGR long block from 2004 with (cable driven throttle) will work in a 2005 (drive-by-wire throttle) if the intake manifold is swapped? Link to comment Share on other sites More sharing options...
Gloyale Posted January 20, 2018 Share Posted January 20, 2018 yes will work for 05, but not for 06 or newer. 06 uses AVLS (active variable lift system) valves with specific type heads. and pistons. But yes 04 253 should work in an 05 as long as it's not AVLS Link to comment Share on other sites More sharing options...
iriejedi Posted January 26, 2018 Author Share Posted January 26, 2018 (edited) Thanks for the confirmation Gloyale! Edited January 26, 2018 by iriejedi Link to comment Share on other sites More sharing options...
