garspeelin Posted January 26, 2018 Share Posted January 26, 2018 The dealership expressed the importance of getting oil changes at the dealership and nowhere else because of a plug or gasket issue. Where does other Outback owners get their oil changes? Walmart is like 60$ cheaper. Link to comment Share on other sites More sharing options...
mikec03 Posted January 26, 2018 Share Posted January 26, 2018 LOL Thanks for the good laugh this morning. Actually I should thank your dealership. The problem is that some nomnuts will drain your CVT instead of your oil pan. Or they won't use a new compression gasket. Or they will over torque the drain plug. I change my oil in my driveway. Of course, for a lot of people live in apartments and can't change their own oil. It is kind of scary to have it changed at someplace like Walmart. I can't deny that. You could eliminate most of the problem by telling the manager that you need to show the mechanic before he starts. Boy, I'll bet they would love your for that! Just for the record, I reuse the compression gasket often, and I put as much force as I can with a 8/9" wrench, and I add a couple of jecks even after it's full tight. I never have had a problem. 1 Link to comment Share on other sites More sharing options...
GeneralDisorder Posted January 26, 2018 Share Posted January 26, 2018 Full synthetic. Any competent MECHANIC can do it - read reviews, etc. Walmart and oil change chain stores are to be avoided - these people are clueless. Dealer lube techs aren't much better than Walmart. If you think a real mechanic is doing it at the dealer.... LOL. GD 1 Link to comment Share on other sites More sharing options...
golucky66 Posted January 26, 2018 Share Posted January 26, 2018 You do not NEED to go back to the dealer for anything except free warranty work. The issue is, as mikec03 said. Quick lube places as well as chain shops can very easily mess up services. The best thing you can do is find a GOOD independent Subaru shop and go there for everything. And in my opinion and experience, if you don't replace that crush gasket every service, they will leak. But I don't go crazy tight. Just as tight as needed. Link to comment Share on other sites More sharing options...
Rooster2 Posted January 26, 2018 Share Posted January 26, 2018 As Mikeec03 stated, the crush washer used on the oil pan drain bolt can be re-used multiple times. I have always changed my oil, so am confident on this subject. Crush washers can be purchased at the dealership parts department for little money, if and when needed. I, too am not confident that the oil change guys at Walmart can be trusted. They don't hire the smartest people at Walmart, so be aware they can make mistakes. The oil changes shops do a decent oil change, but always try to sell you things you don't want or need, like new wiper blades, or air cleaner filter. I usually tell them I am going to be trading in the car, and don't want to put any money into it. That gets them off my back. Well, saying this is true, but in reality, I won't be trading in the car for another 5 or 6 years, so it is not telling a lie. . Link to comment Share on other sites More sharing options...
idosubaru Posted January 26, 2018 Share Posted January 26, 2018 (edited) you can have it changed anywhere but you should favor a shop that does great work. i'd pay more for a good shop than just bargain hop. it's a cheap way to maintain a good relationship. i get tires from a place because they're a good business. it costs me more but i've got a relationship with a long term, well run establishment where i know most of the staff. it's worth the additional cost and it's worth considering that option for oil changes as well. And in my opinion and experience, if you don't replace that crush gasket every service, they will leak. But I don't go crazy tight. Just as tight as needed.i've seen aftermarkets leak before the first oil change, but I routinely put 50,000 and 100,000 miles on the same *OEM Subaru* crush washer and never replace them. but that's not the topic here, there's no reason not too and you should always replace it for sure. Edited January 26, 2018 by idosubaru Link to comment Share on other sites More sharing options...
lmdew Posted January 27, 2018 Share Posted January 27, 2018 Do it yourself so you know it's right or find a good independent shop and go there for everything. 100+ to what idosubaru said! Link to comment Share on other sites More sharing options...
GeneralDisorder Posted January 29, 2018 Share Posted January 29, 2018 We replace the crush washer with a new copper one every time. Cost less than 1/3 of the dealer unit and just as effective in my experience. Not that its a great savings but we buy them in bulk. The dealer ones come in little plastic bags one at a time - takes forever to unwrap them all. We buy them in boxes of 50. Time is money and fiddling with 50 little baggies.... GD 1 Link to comment Share on other sites More sharing options...
carfreak85 Posted February 1, 2018 Share Posted February 1, 2018 The copper washers are even reusable indefinitely, if you anneal them between uses, that is. Link to comment Share on other sites More sharing options...
Mike104 Posted February 1, 2018 Share Posted February 1, 2018 (edited) The copper washers are even reusable indefinitely, if you anneal them between uses, that is. Used to do that on airplane spark plug changes on small piston powered aircraft. Now we just toss the $1,000 +igniter with the gasket in the trash for jet engines. http://www.skygeek.com/champion-ch34630-igniter.html?utm_source=googlebase&utm_medium=shoppingengine&utm_content=champion-ch34630-igniter&utm_campaign=froogle&gclid=EAIaIQobChMIpMmG-rCF2QIVj4zICh2tewouEAkYCSABEgLD6fD_BwE Edited February 1, 2018 by Mike104 Link to comment Share on other sites More sharing options...
GeneralDisorder Posted February 2, 2018 Share Posted February 2, 2018 The copper washers are even reusable indefinitely, if you anneal them between uses, that is. Assuming they aren't squished to oblivion.... and you want to get out the torch to anneal a $0.30 copper crush washer. Time is money and that's more than $0.30 worth of time and maybe more than $0.30 worth of propane. GD Link to comment Share on other sites More sharing options...
impostor Posted February 2, 2018 Share Posted February 2, 2018 +1 for replacing the washer every time. I've got better things to worry about than a washer that costs so little. To the op, the dealer is partly right. There are still places that screw up an oil change. I still see one, sometimes two cars a year that come in with 10 quarts of oil in the engine and a slipping transmission. I've even seen the t70 torx plug for the front diff chiseled loose (thinking it was the engine oil drain plug.) I wish I knew what people were thinking sometimes. Link to comment Share on other sites More sharing options...
subnz Posted February 3, 2018 Share Posted February 3, 2018 (edited) The copper washers are even reusable indefinitely, if you anneal them between uses, that is. Agree have never ever replaced one of these. Also agree the problem is that the drain plugs are over tightened and crush the washers. - it's only a drain plug and only needs to be nipped tight with a ring spanner holding it in the middle. -Not a socket and bar / torque wrench Edited February 3, 2018 by subnz Link to comment Share on other sites More sharing options...
Souperoo Posted February 4, 2018 Share Posted February 4, 2018 To the op, the dealer is partly right. There are still places that screw up an oil change. I still see one, sometimes two cars a year that come in with 10 quarts of oil in the engine and a slipping transmission. I've even seen the t70 torx plug for the front diff chiseled loose (thinking it was the engine oil drain plug.) I wish I knew what people were thinking sometimes. I'm a newbie here and to a Subaru. Been changing my oil for many many years and with the plastic shroud under my Forester, I actually looked in the owners manual for the oil filter location. If you follow the manual it points you to the oil filter and the transmission drain plug! It didn't look right to me so I looked further and found the real engine oil drain plug about a foot away from where the manual states. Maybe that's why so many drain the tranny? Link to comment Share on other sites More sharing options...
idosubaru Posted February 5, 2018 Share Posted February 5, 2018 If you follow the manual it points you to the oil filter and the transmission drain plug! engine oil drain plug about a foot away from where the manual states. Maybe that's why so many drain the tranny? are you sure? But it’s doubtful, most don’t look at the manual. if it were true then it would happen more to vehicles with confusing manuals and not to others. I don’t think that distinction is happening. Link to comment Share on other sites More sharing options...
TurboRev Posted February 7, 2018 Share Posted February 7, 2018 Great read. Thanks for the info everyone. Link to comment Share on other sites More sharing options...
Souperoo Posted February 7, 2018 Share Posted February 7, 2018 are you sure? But it’s doubtful, most don’t look at the manual. if it were true then it would happen more to vehicles with confusing manuals and not to others. I don’t think that distinction is happening. I looked again. It's less than 1 foot away but you can't see it from where the book tells you to look through a little panel comes off of the big panel underneath. Link to comment Share on other sites More sharing options...
