Check engine light on 93 loyale
I have noticed the check engine light intermittently lighting up. Sometimes in the morning and sometimes while it's warmed up. If there is a problem in the morning the car is a little harder to start like the choke isn't working. Of course it's efi, so that doesn't make sense, but maybe it's the cold start injector or something like that. If it lights up when the car is warm it really doesn't have any power, like it's in limp mode. how can I read the codes, or does someone have ideas on this symptom?
  • Like 1
Great reference: http://www.ultimatesubaru.org/forum/topic/47526-subaru-ecu-codes-for-1983-1988/
This still applies to the Loyales
-- 1988 and Later Models With Single-Point Fuel Injection --
CODE PROBABLE CAUSE
11 Crank Angle Sensor or Circuit
12 Starter Switch or Circuit
13 Crank Angle Sensor or Circuit
14 Fuel Injector - Abnormal Output
21 Coolant Temperature Sensor or Circuit
23 Air Flow Meter or Circuit
24 Air Control Valve or Circuit
31 Throttle Sensor or Circuit
32 Oxygen Sensor or Circuit
33 Vehicle Speed Sensor (VSS) or Circuit
34 EGR Solenoid or Circuit
35 Purge Control Solenoid or Circuit
42 Idle Switch or Circuit
45 Kick-Down (Detent) Relay or Circuit
51 Neutral Switch Continuously in the On Position
55 EGR Temperature Sensor or Circuit
61 Parking Switch or Circuit
I can't recall if you have to connect the test plugs or not with the loyales, I seem to recall my old 90 loyale would show the ECU blinking lights with the key turned on regardless.
And these could be helpful too:
http://www.ultimatesubaru.org/forum/topic/18385-reading-codes-on-94-loyale-edit-92-not-94/
http://www.ultimatesubaru.org/forum/topic/3992-one-more-timehow-do-you-check-ecu-trouble-codes-on-ea82/
Basically you remove the plastic guard under the steering column to view the LED on the ECU. The process of connecting the test cables is listed in the post(s) above.
Edited by Ibreakstuff
When the code is a tive, you don't need to connect anything. If it's intermittent, the memory connection will show those.
Check the CTS. With an ohm meter, and the table in the fsm. It is the 2 wire sensor on the lower thermostat housing.
