Upgrade head lights 1986 dl wagon
You are going down a path of glare, purposely misaligned headlamps, angry, blind drivers and other miscellaneous woe and sorrow.
Do a search for Turbone and his HID headlamp upgrade.  The way he upgraded his lamps is really the only way to do it properly.  You can't just stick HID bulbs in a halogen housing.
  • Like 1
DL, not a halogen fixture.
He can simply bolt in a replacement fixture that fits the OE quad lamps hole.
Still obnoxious and I will shine my brights at him happily.  I hate HIDs
Edited by Gloyale
  • Like 3
I hate HIDs
We should get jackets!
Even factory fitted HIDs are garbage. Who ever thought they were a good idea should be shot.
Cheers
Bennie
Edit: best bang for buck is an auxiliary wiring loom that references the factory loom but provides more amps/voltage at the globes due to newer/better wiring. This also allows you to run higher wattage globes if you so desire. Always stick with 55w low beam globes though or run the risk of a lot of blinded angry drivers that might have brighter high beam lights than you do, like this:
:D
Edited by el_freddo
  • Like 1
