Dake Posted February 21, 2018 Share Posted February 21, 2018 (edited) Those who read my other threads know I encountered a block that probably isn't worth the effort in my 2003 Forester EJ251. As luck would have it someone just posted a t-boned 1999 Forester 5 speed not far from me, with under 70,000 original miles. It has been sitting in a garage for a year but still runs and will drive. It's 3 hours away or I'd just drive over there to answer my ?s. The problem I'm encountering is a bunch of conflicting info on what engine it might actually have. Wiki is very specific that the EJ25D was only in the 98 Forester, and 99 had either a 251 or 253, but now I can't figure out which it is. Plus a bunch of threads say that 99 Foresters had Phase 2 EJ25Ds. Are there any photos I could ask him for that would answer that? Of course either way I could just swap my heads onto this block, I'd just love to drop the whole thing in and call it good for now (if it doesn't leak etc, and do the timing belt). Will the 0.09 thousandths the machine shop took off my 251 heads cause clearance issues if I bolt them up to a different block? Edited February 21, 2018 by Dake 1 Link to comment Share on other sites More sharing options...
matt167 Posted February 22, 2018 Share Posted February 22, 2018 1999 has an EJ253. It is Phase 2 but uses a MAF sensor. 251 came in 2000 and uses a MAP sensor.. 251 and the early 251 are basically mechanically the same Link to comment Share on other sites More sharing options...
Dake Posted February 22, 2018 Author Share Posted February 22, 2018 OK that clears that up, so swapping my heads onto that block is the answer. I imagine you'd have to take off a lot more than 9 thousandths to start colliding things. Link to comment Share on other sites More sharing options...
Gloyale Posted February 22, 2018 Share Posted February 22, 2018 look at the heads. do the plugs go straight in from teh side, or angled from teh top? If the 99 donor is actually a SOHC (plugs anged in from top) then you can simply drop it in...no need to swap your heads. might need to swap cam/crank gear but then just use the 2004 manifold. And about the heads......Do you mean .09 Thousands (which is 9 tenthousands or .0009) or 9 thousands (.009)? Big difference. but either way the limit is 12 thousands ( which is .012) which is .3mm in metric. So they are way good at .0009, but at .009, they may not be able to be cut again at all. Link to comment Share on other sites More sharing options...
idosubaru Posted February 22, 2018 Share Posted February 22, 2018 99 is Phase II EJ25 (not EJ25D). This is of course presuming they listed the year correctly. 99 and 03 forester engines are interchangeable. EJ251/253 doesn't matter for interchange, just swap the intake manifold and drivers side cam and crank gear and anything else necessary, the long blocks are interchangeable. 1 Link to comment Share on other sites More sharing options...
Dake Posted February 22, 2018 Author Share Posted February 22, 2018 (edited) Sorry yes 9 thousandths (0.009), I noticed that typo just now. I called Subaru and verified the VIN as a 99, so it sounds like everything should be good to go and not as complex as I had feared. Enjoying working on Subarus more at every step Edited February 22, 2018 by Dake Link to comment Share on other sites More sharing options...
