Subotai Posted February 27, 2018 Share Posted February 27, 2018 Hi everyone I am brand new to the forum, and I tried a few different phrasing in the search bar for this question; please forgive me if it has already been answered. I have a 2011 Impreza hatchback and a small accident has rendered my right back passenger door kinda crumpled. I found a door on Craigslist from a 2009 Impreza sedan (non-turbo). I've contacted the seller and he assures me he has used parts from this make and model on his own Impreza hatchback. Does anyone know what makes and years are compatible without buying a haynes or chilton manual? This would be a very nice easy fix for me as the colors match already and I'm fairly certain it looks like my door, just need some confirmations before committing. Thank you for any help and advice. 1 Quote Link to comment Share on other sites More sharing options...
Mike104 Posted February 27, 2018 Share Posted February 27, 2018 Go to www.car-part.com and it will tell you what years will fit Quote Link to comment Share on other sites More sharing options...
heartless Posted February 27, 2018 Share Posted February 27, 2018 Go to www.car-part.com and it will tell you what years will fit What he said ^^ a quick look and it would appear 2008 to 2011 are all compatible, but not knowing for sure what exact model you have, it would be best if you check yourself Quote Link to comment Share on other sites More sharing options...
Subotai Posted February 28, 2018 Author Share Posted February 28, 2018 Thanks for the quick responses. any paperwork i have on the car says 2011 Impreza 2.5 SW 4WD, I'm not sure what else can narrow it down as i don't know what to look for exactly. But I did do as you said and went to the car part site. To make it easier I just entered my VIN number. and should I assume anything that pops up in the search is a viable option for me? Heartless, as you said, I see things from 2008 on up. thanks again. Quote Link to comment Share on other sites More sharing options...
heartless Posted February 28, 2018 Share Posted February 28, 2018 yes, using your VIN will make sure you get correct listings. Quote Link to comment Share on other sites More sharing options...
idosubaru Posted February 28, 2018 Share Posted February 28, 2018 Then it should work for you. Sometimes the interior trim differs, you just swap the interior trim panels and that should be all you need to do. I’m general but unlikely to be the case for you - the Exterior can have slight differences between cladding and pin stripping. In rare cases the color can change - “red” might be a “canyon red” in early years of a given generation while later models of that same generation use “mica red”. That’s just an illustration and usually it’s not the case, just something to look out for. 00-04 Outbacks have this issue where 00-01 “red” and 02-04 “red” are different colors even though they’re interchangeable and both “red”. Quote Link to comment Share on other sites More sharing options...
Subotai Posted February 28, 2018 Author Share Posted February 28, 2018 yeah the interior is completely different color, not that it's a really big deal, but mine is all intact so i''ll just you-tube how to take it all apart and swap stuff. You guys have been great. Quote Link to comment Share on other sites More sharing options...
idosubaru Posted March 1, 2018 Share Posted March 1, 2018 i've never encountered a subaru interior panel that was even remotely hard to remove. couple screws and pry them off with an appropriately flat/stiff tool. plastic would ensure you don't scratch anything, but i routinely use long screw drivers having done it countless times. Quote Link to comment Share on other sites More sharing options...
heartless Posted March 2, 2018 Share Posted March 2, 2018 i've never encountered a subaru interior panel that was even remotely hard to remove. couple screws and pry them off with an appropriately flat/stiff tool. plastic would ensure you don't scratch anything, but i routinely use long screw drivers having done it countless times. completely agree... and the little plastic clips are cheap to replace if you break one or two in the process - altho I dont think I have ever broken a Subaru door panel clip... that was the Dodge, lol Quote Link to comment Share on other sites More sharing options...
Subotai Posted March 4, 2018 Author Share Posted March 4, 2018 I will tackle that part next. Yesterday went really smooth with the buy and the install. it was about five bolts and unhooking/reconnecting a power line. It has some metallic flakes in it so it's not a 100% match but for the money saved, I'm not going to worry about it. 1 Quote Link to comment Share on other sites More sharing options...
